Joystick (Xinput) icon Joystick (Xinput) — XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts. Try it →
I think i need to start using a better cam for filming my bots the ipod seems just a bit to grainy for me
Just added some new photos of scraps
Wolfie, That is one very determined robot in your video.
The drive system is powerful. Scraps is very cool and nice video demonstration. Steve S
Yes it dose have some power for its size:D the base was from an RC snow cat from radio shack and now moves alot more wight than before. I cant wait to see it working in the snow When it was just an RC plow it did ok with up to 3" deep dry snow on my deck should be better now that it wight is alot more and seen how good it climbs when it has traction :D
Soon the blade will be working then i need to work on a better power system for it "I want to power it all on less than 1.5 volts" wish me luck on that part lmao
Great build Wolfie. Why do you want it to run on such low voltage?
then my batts will last alot longer and cost way less to power it
#16
the ez-b needs a min 6v. how do you suppose you get around that.
