Intel Realsense T265 icon Intel Realsense T265 — T265 VSLAM for ARC: SLAM-based mapping and precise way-point navigation, low-power tracking, and NMS telemetry. Try it →
Resolved Resolved by Jeremie!
Is This Warenty
Is This Warenty
i make another topic about the batteries cause this can be a case of warenty. the chargers says output 12 volt,i get 12.22 volt .i think thats ok the charger gifs 11.20 something to low.so i look at the batt in jd win8, and it wil not charge,green led goes out.i also see some punctering in the batt, from i gess factory.i made a video.the balancers gifs 8.22 volt on 1.15 hour, and led goes out.gess also perfect.when i messure the wire itself ,i get , about 12.20 volt.so can this be warenty.also i think if the other jd's dont have it. i got now 4 death batteries and 1 bad charger.i use the robots 1 or 2 times, a week.
the dianostic rapport chould be there now
i found a better way to messure the volt of the adaptors.
the adaptor says 12.00 volt ,i got one 12.26 v 2x 12.24 v
i always learn what the output says must be steaddy there.12.00 volt.
els it whould be undercharge or overcharge
bolt will kill the batt.i gess this happened the first time the balancers,chargers. where not good.but i had use them for a while before i notest something.
eather the first one kill the batts or the balancers or ( adaptors )now.
#19
12.00v or 12.24 volts doesn't matter... .24 of a volt is nothing... What matters is if your charger fails to switch from fast charging to trickle charging. If it doesn't then it will overcharge the battery causing failure.....
Red Leds = fast charging...
Green Leds = finished charging/trickle charging
rr
i have the old ones the blue
#21
I guess it's time to update you battery chargers then... You spent a lot of money on these batteries and robots.... Buy the new charger so you won't damage any more batteries or robots.... Seriously nomad, the new charger is much better than the old one...
i allredy bouth 1 batt and 1 new charger here.
whats your annest opinion ,chould this be warrenty or not?
i can only by one at the time.the customs here has tripple the cost. for dilivery.
i got the batt and charger and balancer less then a year.
clock is tikking tik tok untill tomorow noon then i make some real video's. mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad mad
#24
Oh goodie a show down at 12noon at the ok coral.... :D
Hmmm, is that EST time or MST where DJ lives? Or your time?:D
