i did plug it into the router port192.168.0.33 with wire then if he's connected,take wire out and go to 192.168.0.30 then he got wifi and you can connect to choreograph and it also in engenius cause its wifi
#18
I dont know what that robot is doing on the network end, but it is possible I guess for it to need to be connected to then set the network settings.
If it is now working, great.
sofar nothing,i got this error.
#20
A router port does not have a fixed IP. Moving a cable from one port to another will not reassign IPs to devices any more than resetting or power cycling the router would do.
Perhaps you should stop attempting to use such items which require some knowledge on the item until you have gained an understanding of how they work?
P.S. If you used a decent PC repair company you would not have lost your password from a simple hard drive swap. Every hard drive swap I have ever done (and there have been hundreds) the new hard drive mirrored identically that which was removed.
rich
your first answer i get that. second all robot programms says easy in use.so i bouth it. just like ez robots.for the repair man,i dont now why it was needed, so i cant judge that.did you never by something you had to learn. you cant learn anything from nao before you own one.
#22
No but you should have some understanding of it and a general understanding of everything it uses. It seems to me you are unable to comprehend even the simplest of tasks which are required should you want to enjoy hobby robotics.
Nao may look great, he may work great for those who can understand how to operate him but from everything I have read, it seems you struggle with anything more advanced as pre-programmed EZ-Robots. All I'm saying is it may be time to stick to things which you have the skillset to operate and understand.
rich
yes i do not understand any of robots,not even ez robots. my heart was bigger then my brain. no matter what i try i cant get it in my head.so thats leaves only one thing left. quit my robot hobby,i have just bad luck having a bad brain.
well thanks for your advise aldo it hurts a lot.
lets close this topic and goodby
#24
@nomad... please stop being a martyr and melodramatic... get on google and fix this... If you can't then sell it and stick to EZ Robot... You are doing very well with ez robot... Stick to what you know and stop shooting yourself in the foot will ya'...
