Pushover icon Pushover — Send robot status alerts to iOS, Android and Windows via Pushover.net. Configure User/App keys to notify on low battery, stuck or task events. Try it →
Resolved Resolved by Nomad 6R!
Integrating EZ-B with InMoov Head
Integrating EZ-B With Inmoov Head
Hello everyone,
I am in the process of upgrading my current InMoov robot head to be controlled by an EZ-B controller, replacing the previous setup that used MRL (MyRobotLab). To move forward with this modification, I am searching for a specific part that is essential for this integration.
Could anyone guide me on where I can purchase this part or provide instructions on how to build it? Links to resources, STL files for 3D printing, or part suppliers would be extremely helpful. I am especially interested in understanding the switch located at the back of the head and how the IO Tiny module is utilized within this configuration.
Thank you in advance for your help!
EZ-Inmoov Robot Head by EZ-Robot & Gael Langevin
EZ-InMoov Robot Head with Synthiam ARCx: face tracking, speech recognition, Talk Servo jaw motion and AI conversation
Servos 8
ADC 2
Digital 8
Hi there!
It sounds like you’re working on converting your InMoov head from MRL to an EZ-B/IoTiny setup. I’d be happy to help clarify the process and point you toward the resources you need.
Below are some details and suggestions:
  1. The Role of the IO Tiny and Switch
    In the EZ-InMoov head design, the IO Tiny is used as the interface between the head’s servos/sensors and the EZ-B controller.
    The switch you’re referring to (located at the back of the head) is part of the design that lets you change power/control modes or signal a certain state. In the EZ-InMoov hardware, this switch is integrated into the mounting bracket/connector that holds the IO Tiny in place.
  2. Where to Find the Parts & STL Files
    The EZ-InMoov Robot Head product page on Synthiam’s website provides detailed assembly instructions, parts lists, and STL files for 3D printing the necessary components.
    • Visit: EZ-InMoov Robot Head Support
      In that support resource, you’ll find the assembly PDF and links for the 3D print files for all custom parts (including the bracket for the IO Tiny and the switch assembly).
  3. Adapting Your Current Head
    If you’re rebuilding your head, compare your current setup to the EZ-InMoov head documentation. The provided mounting hardware and wiring harness are designed for the IO Tiny and EZ-B integration.
    If you’re missing a particular bracket or switch piece, the STL files and parts list on the support page will show exactly what you need to print or order.
  4. Wiring & Integration Tips
    The IO Tiny is wired to handle the servos (for jaw, eyes, head pan/tilt) and any sensor inputs. The documentation explains how the IO Tiny mounts into the head assembly and connects with the existing wiring harness.
    Double-check your wiring against the illustrated diagrams in the assembly instructions (often included as step-by-step guides) to ensure that the switch and IO Tiny connections are correct.
  5. Next Steps & Additional Guidance
    Review both the hardware page and the assembly instructions to see how the IO Tiny is integrated and how the switch is mounted.
    If you need more specific help (for example, wiring clarifications or additional pictures of the switch integration), let me know what details are most unclear, and I can guide you further.
I hope this gives you a better idea of how to proceed with your modification! Do you have any questions about a specific part of the integration or the wiring diagram? Let’s work together to get your EZ-B powered InMoov head up and running.
Don't know if this is what you are looking for or not?
Link
Good Luck
#4   — Edited
@bhouston that is for the head itself. I'm not looking for that I'm just looking for the part that has the mini deans and power switch on it. I don't see it in the STL files. I have most all the other parts as I have a ez-robot developer kit plus extras. I'm sure that part was a 3d printed part at some point.
Here is what it looks like again:
You can see the switch, a micro deans, deans, and a spot for a fuse.  It's the blue part I'm needing.
@Nomad-6R That's it. Thanks everyone for the help. Much appreciated
The great news is I have the part number now and its really cheap.  The bad news is that since US is NOT so happy with Canada just to ship it literally across the border into Montana is $40. :( ..  I wonder if there is anywhere here that I can get it?
I saw a post a while ago that said ezrobot has a warehouse in the USA. You can reach out to ezrobot and ask about their warehouse.
