Auto Position Movement Panel (Gait) icon Auto Position Movement Panel (Gait) — Create servo frames/actions to animate humanoid, hexapod or custom gaits with smooth transitions, SW ramping and directional control Try it →
Ibm Watson Plug In Service?
I’ve been looking into the services provided by Watson. I’m really impressed. Is this something that could be implemented like the other services we have, like Bing and Microsoft? They have a 10,000 a month limit.
#89
Holy cow! As always job well done! Looking forward to test driving this. Just finishing current robots this week! Hats off to you good sir.
#90
@PTP : I tried your Watson - visual recognition services plugin. Thank you so much for putting in all that effort!
I installed your plugin. I created an IBM Cloud - Watson account. And after bumbling around the IBM site for about 3 hours I finally created my project and API key. I configured the plugin and it IS WORKING FINE!
Also, I also tried the TTS and the STT and I got both of those working too.
Thanks again!
Thomas thomas from la (at) g mail (dot) com
cool:D cool
PS. Do you know if Watson has the ability to locate the objects by x and y coordinates?
#91
I'm soooo impressed and grateful with today's technology at our disposal. Just blows my mind. :-)
The last few days, I finally spent some long overdue time playing with several applications and services such as:
  • Spectral voices for EZB TextToSpeech
  • Microsoft Azure TextToSpeech and TextTranslation
  • PendoraBot
  • IBM Watson Services (SpeechToText, TextToSpeech, and Assistant) with the Plugin.
After many hours of fooling around trying to understand how Watson and the plugin works, I came to a total halt. I can not get the final details to work; for the SpeechToText and TextToSpeech services, I don't get any Voice Model to select. In the Plugin, it says "When the configuration is called, the plugin logs the existent models and voices.", but I get nothing ?!?
When I activate the service (check the Active box in configuration), I get lots of error message in the Debug window. I attached a capture file, I don't know how to add image yet.
Similarly, in the Configuration-Assistant tab, I don't get any workspace selection. But this might be because I haven't create one yet in Watson. Will look into it later...
@ptp Got the EZB plugin. Got the URL/Username/Password. Filled up all configuration details in the plugin.
My problem is I can not get any voice model selection. When I click on Model, the only selection available is "No speech models (check credential)". Are those speech model from my windows speech (voices) or from IBM Watson Service cloud that I have to configure or select or whatever ?
#95
Hey @kazobond
I'm sorry that I can't help you but I've got a question on the following plugins that you tried for speech to text and similar.
When you will be able to run the Watson one. Could you please tell me which one was better than the others ?
You would save me a lot of time:)
Cheers !
It's seems you have an invalid endpoint url:
There are some characters and spaces before the "https:"
