SMTP Client icon SMTP Client — Send SMTP email (text or camera images) from ARC robots via ControlCommand; configure SMTP/auth and sender; saves credentials in project. Try it →
Netherlands
Resolved Resolved by rickymahk2013!
Humanoid Project Full Scale
Hi ,
i want to build a humanoid robot , that walk on 2 legs. i , figure i need strong servo´s that provite the weight. because my humanoid robot become about 190 cm high. but i not sure if i can use normal servo´s from the EZ-b developer kit. i think that is to weak to suport movement. also i want build a accu 12 volt or 24 in it. so he have power on is onw while. I hope someone can help me.
regards Michael
Netherlands
#33
Hi Richymahk2013,
do you have my mail?
best regards Michael
Netherlands
#34
this my next problem. my computer will not run the software. if this not work so can i. so you see above picture. here is a previeuw what i gonna do.
Did there error happen during the installation? Or when first opening the program? Or where you running something in ARC, like a script?
#37
That's an odd error @RoboMicke. I assume it happened at runtime, yes? Or when you went to open the ARC application. Did you click "Ja" to view the help information? What did it say?
The error appears to be related to how the .NET framework hendels your computers location and default language settings. From MSDN
But, because the error code specifically tells you what the issue and gives you an option to view help notes, it is safe to say DJ and the EZ-Robot team are aware of this, because they set the error message to handle it.
#38
Awesome @thetechguru! I can confirm you can change the decimal setting in Windows 8.x by using those directions.
Who knew those were there, LOL? :)
#39
Quote:
Who knew those were there, LOL? Smile
I have seen this before with some software I supported in my previous job, which was all written for North America and UK computers, but had worldwide distribution.
We wound up changing the software to handle other locale settings better, but unfortunately I have no idea what changes were made, so can't provide any advice for DJ on that front.
Netherlands
#40
the problem is right at the start of the ez-b builder. when I click on yes I come on this link :
https://synthiam.com/Community/Questions/2806
I do not know what to do.
the last update that made my computer. has changed my program. I have now with my email address to login instead of my old code I had. for the computer program are changed.
my computer can not stand on two days. then get my desktop black. and the computer icons will not to respond. it freezes. fortunately I can reboot the computer. and the weather seems to do normally. until there two days are over. then it starts again.
I'm going through my ideas. maybe I should run to the store and ask what I can do. as a last option.
