Cognitive Vision icon Cognitive Vision — Microsoft Cognitive Vision integration for ARC: real-time object, face, emotion detection, OCR, confidence data and script-triggered robot actions. Try it →
Help With Error On $botresponse Aiml
Help With Error On $Botresponse Aiml
Quick question as I am editing the settings file for the AIML Bot plug in. I got a clean set up with just the AIML Bot plug in. Mostly works just fine, but on occasion I get a correct $BotResponse that is not spoken, with an error message. Can anyone tell me whats happening.
Again correct response is given, just wont speak the response do to error?!
ptp, is it new lines in the source files? It looks like some number of characters in the screenshot. I've been out at a conference all day and traveling - I'll take a peek now that i'm back at my hotel
I noticed these similar errors as well on certain bot responses. Like Will said, the bots response will show up in the text response window, but not spoken using either Say() or SayEZB() and shows an error in the ARC debug window. Do you also notice the large spaces in the sentence of the bots response that is NOT spoken (look for n post #6). A spoken response will not have this large space and a response that is not spoken with a debug message, will.
After some troubleshooting, I did find one possible cause in some of the AIML files. Don’t quote me on the exact tags as I’m not near a computer right now, but It had something to do with a bots template response that contained < Set > < Name > or < Topic > tags. The tags actually fit in the large spaces in the sentence of the bots response I mentioned above. It’s essentially giving two responses in one sentence, the first half of the sentence, then the topic which contains and redirects to the second part of the sentence, and I think there in lays the problem.
Example: First part of the response...
"My favourite movie is 2001 a space Odyssey. "
Then the topic tags that sets the movie name, followed by the second part of the response (look in the AIML response window in post #6, you will see the large space between the above response and the one below), ...
"Have you seen 2001 a space Odyssey?"
What I tried on one response that gave a debug error, was to delete the above Name, Set and Topic tags and left just the Category, Pattern and template tags with the original user question and slight change to the bots template answer as I removed the set topic for the movie name, so instead of "Have you seen 2001?", I put "Have you seen it?". Saved the edited file, reloaded it in the AIML control and this actually did stop the debug error and the response was spoken. Did this on a couple more responses with the same results. Not an ideal fix but good for trial and error as I got a result and hopefully will help with finding a solution.
I had the error pop up with favourite movie, fav band and fav song. I’m still going through this and when I’m by a computer tomorrow, I’ll see if I can find the exact AIML tags that throws the error up and let you guys know. Hope what I have posted so far is of some help.
Steve.
@Steve G: The problem is related to the linefeed character 0x0A.
A temporary fix script:
create a file "fix_linefeed.vbs" paste the following content/script:
Option Explicit
Main
Sub Main
    Dim Path
    Dim FileName
    Dim Files
    Path = "C:\Users\Public\Documents\EZ-Builder\Plugins\aa184830-399a-4716-bdfc-e766fd792a51\aiml\*.aiml"
    Files = ListDir(Path )
    If UBound(Files ) = -1 then
        WScript.Echo "No aiml files found."
    Else
        For Each FileName In Files
            WScript.Echo FileName
            FixLineFeed(FileName )
        Next
    End If
    Path = "C:\Users\Public\Documents\EZ-Builder\Plugins\aa184830-399a-4716-bdfc-e766fd792a51\config\*.xml"
        WScript.Echo "No xml files found."
    Else
        Next
    End If
End Sub
Public Sub FixLineFeed(ByVal FileName )
    Const ForReading = 1, ForWriting = 2
    Dim fs, txt, contents
    Set fs = CreateObject("Scripting.FileSystemObject" )
    Set txt = fs.OpenTextFile(FileName, ForReading )
    contents = txt.ReadAll
    txt.Close
    contents = Replace(contents, vbCr & vbLf, "[CR-LF]" )
    contents = Replace(contents, vbLf, "[CR-LF]" )
    contents = Replace(contents, vbCr, "[CR-LF]" )
    contents = Replace(contents, "[CR-LF]", vbCR & vbLf )
    Set txt = fs.OpenTextFile(FileName, ForWriting )
    txt.Write contents
    txt.Close
End Sub
Public Function ListDir (ByVal Path )
   Dim fso: Set fso = CreateObject("Scripting.FileSystemObject" )
   If Path = "" then Path = "*.*"
   Dim Parent, Filter
   if fso.FolderExists(Path ) then      ' Path is a directory
      Parent = Path
      Filter = "*"
     Else
      Parent = fso.GetParentFolderName(Path )
      If Parent = "" Then If Right(Path,1 ) = ":" Then Parent = Path: Else Parent = "."
      Filter = fso.GetFileName(Path )
      If Filter = "" Then Filter = "*"
      End If
   ReDim a(10 )
   Dim n: n = 0
   Dim Folder: Set Folder = fso.GetFolder(Parent )
   Dim Files: Set Files = Folder.Files
   Dim File
   For Each File In Files
      If CompareFileName(File.Name,Filter ) Then
         If n > UBound(a ) Then ReDim Preserve a(n*2 )
         a(n ) = File.Path
         n = n + 1
         End If
      Next
   ReDim Preserve a(n-1 )
   ListDir = a
   End Function
Private Function CompareFileName (ByVal Name, ByVal Filter ) ' (recursive )
   CompareFileName = False
   Dim np, fp: np = 1: fp = 1
   Do
      If fp > Len(Filter ) Then CompareFileName = np > len(name ): Exit Function
      If Mid(Filter,fp ) = ".*" Then    ' special case: ".*" at end of filter
         If np > Len(Name ) Then CompareFileName = True: Exit Function
         End If
      If Mid(Filter,fp ) = "." Then     ' special case: "." at end of filter
         CompareFileName = np > Len(Name ): Exit Function
         End If
      Dim fc: fc = Mid(Filter,fp,1 ): fp = fp + 1
      Select Case fc
         Case "*"
            CompareFileName = CompareFileName2(name,np,filter,fp )
            Exit Function
         Case "?"
            If np <= Len(Name ) And Mid(Name,np,1 ) <> "." Then np = np + 1
         Case Else
            If np > Len(Name ) Then Exit Function
            Dim nc: nc = Mid(Name,np,1 ): np = np + 1
            If Strcomp(fc,nc,vbTextCompare )<>0 Then Exit Function
         End Select
      Loop
   End Function
Private Function CompareFileName2 (ByVal Name, ByVal np0, ByVal Filter, ByVal fp0 )
   Dim fp: fp = fp0
   Dim fc2
   Do                                  ' skip over "*" and "?" characters in filter
      If fp > Len(Filter ) Then CompareFileName2 = True: Exit Function
      fc2 = Mid(Filter,fp,1 ): fp = fp + 1
      If fc2 <> "*" And fc2 <> "?" Then Exit Do
      Loop
   If fc2 = "." Then
      If Mid(Filter,fp ) = "*" Then     ' special case: ".*" at end of filter
         End If
      If fp > Len(Filter ) Then         ' special case: "." at end of filter
         CompareFileName2 = InStr(np0,Name,"." ) = 0: Exit Function
         End If
      End If
   Dim np
   For np = np0 To Len(Name )
      If StrComp(fc2,nc,vbTextCompare )=0 Then
         If CompareFileName(Mid(Name,np+1 ),Mid(Filter,fp ) ) Then
            End If
         End If
      Next
   CompareFileName2 = False
   End Function
then execute:
cscript fix_linefeed.vbs
and the problem is gone.
PS: No harm is done, if you run multiple times the script.
new plugin is updated to work now without being affected by line feeds
Thanks, really important this works in my meeting.
#15
Thanks for finding the error ptp and for the update DJ.
There is something about updating the AIMLBot plug in that people should be aware of.... after the hours and hours of AIML file editing I have put in to my project over the past couple of weeks, updating the plug in has now replaced all of my edited Config settings and more to the point, ALL of my edited AIML files with the default files, so all my changes have now been over written and lost and I will have to start again from scratch. mad
So if like me you have spent a looong time editing to make lots of changes to personalise your AIML files... make sure you do a back up of your edited AIML and Config folders before carrying out any future AIMLBot plug in updates until a solution is found, so you don't lose all of your work.
#16
@DJ, if we update AIML files in the plugin folder, will plugin updates blow out our file edits? Or potentially blow them out?
Which I guess after reading SteveG last post, actually relates to his post.
