Continuous Servo Movement Panel icon Continuous Servo Movement Panel — Control two continuous servos for bidirectional robot movement with speed sliders, configurable ports/stop values, testing and brake/coast options. Try it →
Help With Error On $botresponse Aiml
Help With Error On $Botresponse Aiml
Quick question as I am editing the settings file for the AIML Bot plug in. I got a clean set up with just the AIML Bot plug in. Mostly works just fine, but on occasion I get a correct $BotResponse that is not spoken, with an error message. Can anyone tell me whats happening.
Again correct response is given, just wont speak the response do to error?!
#17
Yes it’ll overwrite. I’ll think of a solution
#18
@DJ, thank you! I don't say it often enough, but you are awesome! The tools you've brought to the community are amazing! And AIMLBot was a fantastic idea, thank you, thank you for doing that DJ!
#19
I had same issue. But now working on a complete copies of the files in case it happens again. Maybe its opening and pointing the plug to the folder of aiml files you want to use. For me I have one set for ALAN and one set for Alena and a set of unaltered originals.
#20
Can you use aimlbot fully offline with speech recognition?
#21
Not without entering a lot of pre determined phrases. I can modify it to use the internal speech recognition engine without pre defined phrases, but accuracy is terrible lol
#22
@dj Sures     Being able to have a robot offline (like in a public place with no internet) and still able to understand (built-in or using your plugin) and respond (AIML) would be awesome. Sorry @fxrtst not trying to hijack your thread. :):)
#23   — Edited
I'd second that. Even with poor accuracy it would be nice to have as a backup if you are someplace with no internet and bad cell reception.
