Dual Hbridge icon Dual Hbridge — Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed. Try it →
Ez-robot Developers Kit
Ez-Robot Developers Kit
Dear ez-robot,
I got "EZ-Robot Developers Kit" recently. I have a question about battery.
For now, it is using "battery" for electricity. Could it be change to use "AC adaptor"?
Please help and looking forward to having your answer very soon.
Best regards, Ricky Ma 25 Aug 2014
i will thanks
oeps they dont send to belgium,but i got the idea.
dj adaptor
i checked the ones i have.can this one be usefull?
i cant read AMP
2250mA is 2.25 amps.
Depending on what you plan to drive it may work however that may only be enough to power one or two servos.
sorry Rich, somehow I paged beyond your initial post........2250 mA = 2.25 amps
If I use 16kg servo motor x 12pcs. Is it 7.5vdc 6 amp power supply enough to support all servos?
i was looking to power the jd.the batt maybe not reddy for chipping due to , certificate is not reddy yet.so i need to look for 6.00 amp
#16
question is resolved and many thanks for all upon people!:D
