Wowwee MIP V2 icon Wowwee MIP V2 — UART interface to hack WowWee MIP with ESP32/ESP32‑Cam or EZ‑B v4 for ARC; hardware UART preferred, configurable power and baud 9600/115200 Try it →
DepthSensor plugin load error
Depthsensor Plugin Load Error
I was looking for the Kinect Body Control skill but couldn't find it. After some research, I saw that it has been replaced by the DepthSensor robot skill in ARC. I attempted to download the DepthSensor skill, but ARC produced the following error when loading the plugin:
Timestamp: 2026-04-23 15:00:30 UTC
ARC Version: 2026.04.16.01
OS Version: Microsoft Windows NT 10.0.26200.0
Base Directory: C:\Program Files (x86)\Synthiam Inc\ARC by Synthiam\
=== Message Information ===
Unable to load one or more of the requested plugin types.
Update ARC and this plugin from the Synthiam website, then restart your PC and launch ARC.
If an update is available, ARC will prompt you at startup.
If the issue persists, report it on the Community Forum and include this error text.
Error:
System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module)
at System.Reflection.RuntimeModule.GetTypes()
at System.Reflection.Assembly.GetTypes()
at ARC.FormAddControl.VmiJVDQC7f7LxJjUoe4a(Object )
at ARC.FormAddControl.sL05JNDV45(String )
Loader exceptions:
System.IO.FileLoadException
Could not load file or assembly 'EZ-Builder, Version=2015.8.9.0, Culture=neutral, PublicKeyToken=c3a3457c97d352d9' or one of its dependencies. General Exception (Exception from HRESULT: 0x80131500)
The drivers for my depth camera/Kinect were installed correctly (I did not get any errors during installation). I haven't modified ARC settings or other plugins.
Do you have any ideas about what might be causing this, or what additional information (for example, whether the camera is connected directly to the PC or through an EZB, or logs) I should provide?
Converts Xbox 360 Kinect depth frames into NMS obstacle scans for ARC path planning, SLAM, and obstacle avoidance.
Germany
  1. Restart ARC after deleting that plugin folder I deleted it ( i made a backup anyway) I still can not see the skill "kinect body control" in ARC at add project.
  2. Re-add the skill from the store i dont know how to add from the store, i add skills inside ARC. From the store, i see the manual
  3. Use the current Kinect skill instead For Kinect v1, the most likely supported skill in current ARC is: Kinect xBox 360 Depth Mapping this skill has no configuration just the text "test", no click possible. here's a screenshot:
    you wrote: If you want, paste the ARC log lines that appear right after trying to add or load the skill. The exact load failure will tell us whether it is. I'd like to but as i can not see the skill , i can not add or load it. maybe i just need the file plugin.xml ?
Thanks - the screenshot helps.
What I see
Your Kinect xBox 360 Depth Mapping skill is loading, and the little "test" text you’re seeing is likely just a placeholder/test UI from that plugin. That means ARC is definitely loading that skill.
But Kinect Body Control is still not appearing, even after deleting the plugin folder, which strongly suggests it’s not currently available to ARC in a usable form on your setup.
Important point about plugin.xml
No, plugin.xml alone will not fix this.
plugin.xml is only the metadata file ARC uses to identify and load a skill properly.
If the actual plugin package is:
  • missing plugin.xml, or
  • built against an old dependency like EZ-Builder,Version=2015.8.9.0, or
  • otherwise incompatible with ARC 2026,
then ARC may refuse to list it or load it correctly.
Why you can’t "add from the store"
You are already doing the correct thing inside ARC:
  • Project
  • Add Robot Skill
  • search for the skill
That is the right place to add it. The web store is only for browsing info.
What this means
Based on everything you’ve shown:
  • Kinect Body Control appears to be an old legacy skill
  • ARC 2026 is likely not loading it due to compatibility/dependency issues
  • the currently available Kinect option in ARC is the Kinect xBox 360 Depth Mapping skill
About the Kinect xBox 360 Depth Mapping skill
From your screenshot, that skill is functioning, and it looks like it has:
  • a depth image display
  • detection area settings
  • test output
So the skill is alive, even if it isn’t the old body-tracking feature you expected.
Best next step
If your goal is body tracking / skeleton tracking, tell me exactly what you want to do with the Kinect:
  • track a person’s body?
  • detect presence/distance?
  • use hand/arm motion?
  • control movement with the Kinect?
Then I can tell you whether ARC has a current skill for it, or whether we need to build a workaround using a custom robot skill.
If you want to verify the plugin issue
Try this one thing:
  1. Open C:\ProgramData\ARC\Plugins
  2. Look for the folder for Kinect Body Control
  3. If the folder comes back after restart, open it and check whether plugin.xml is present
  4. If it still doesn’t exist, then the skill package itself is probably incomplete or incompatible
If you want, I can help you inspect the plugin folder structure and tell you exactly what files should be there.
The folder containing those files is most likely an incomplete install. Or higher probably, an incomplete uninstall. You can look at the date time on the folder to see when that occurred.
So ARC sees the folder, but the definition file is missing.
an easy fix is to remove that folder: C:\ProgramData\ARC\Plugins\0518bd78-2ac0-487e-ba58-c8b33bd2c81e
In fact, you could remove all folders within C:\ProgramData\ARC\Plugins if you want to ensure a 100% recovery of all robot skills. You will not lose any saved configuration by removing that folder. It would remove the source libraries for the plugins - in which case you would be prompted to install plugins moving forward if needed for a project.
Germany
Thank you for the detailed feedback. I really appreciate your help in troubleshooting this.
I will follow your advice and clean the C:\ProgramData\ARC\Plugins folder to ensure there are no corrupted files or incomplete installations on my end. It’s a great suggestion to start fresh.
Quick question to help me plan my project: Once I've cleaned everything, if the 'Kinect Body Control' skill still doesn't appear in the search, does it mean it has been moved to a legacy status for the 2026 version?
I am a big fan of the JD robot demos using Kinect, and I was hoping to try the same setup. If that specific skill is no longer available, I’m happy to look into other ways like Auto Position or servo Recorder to achieve my goals, but I wanted to check with the experts first so I don't miss something obvious!
Thanks again for your time and for the great support
The connect body control is not legacy status. The other skill which started the conversation is expired and has been removed until the author updates it.
always feels good starting fresh! You’ll be prompted to install robot skills as needed once the folder is removed.
Germany
I have followed your instructions and successfully cleaned the corrupted folders as requested. Unfortunately, the diagnostic is final: despite the cleanup, the skill still does not appear in the ARC Robot Skills search results.
Since the skill remains indexed as missing or unavailable for my version/region, I have decided to pivot my workflow toward the Auto Position skill to move forward with my robot arm integration. Thank you for the assistance provided so far,  I will be proceeding with this alternative solution for now.
#15
This is concerning that it's not showing up for you. I am raising priority to have this issue looked into immediately to find out what's happening. It should be caught and logged, so something is slipping through the cracks. Stay tuned while it's being looked into.
#16
We have made some changes on our end - and would like you to start ARC with an internet connection, and verify if the Kinect robot skill that you are looking is available for installation.
