- I have a question about the ARC robot skill "DepthSensor."
I was looking for the Kinect Body Control skill but couldn't find it. After some research, I saw that it has been replaced by the DepthSensor robot skill in ARC. I attempted to download the DepthSensor skill, but ARC produced the following error when loading the plugin:
Timestamp: 2026-04-23 15:00:30 UTC
ARC Version: 2026.04.16.01
OS Version: Microsoft Windows NT 10.0.26200.0
Base Directory: C:\Program Files (x86)\Synthiam Inc\ARC by Synthiam\
=== Message Information ===
Unable to load one or more of the requested plugin types.
Update ARC and this plugin from the Synthiam website, then restart your PC and launch ARC.
If an update is available, ARC will prompt you at startup.
If the issue persists, report it on the Community Forum and include this error text.
Error:
System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module)
at System.Reflection.RuntimeModule.GetTypes()
at System.Reflection.Assembly.GetTypes()
at ARC.FormAddControl.VmiJVDQC7f7LxJjUoe4a(Object )
at ARC.FormAddControl.sL05JNDV45(String )
Loader exceptions:
System.IO.FileLoadException
Could not load file or assembly 'EZ-Builder, Version=2015.8.9.0, Culture=neutral, PublicKeyToken=c3a3457c97d352d9' or one of its dependencies. General Exception (Exception from HRESULT: 0x80131500)
The drivers for my depth camera/Kinect were installed correctly (I did not get any errors during installation). I haven't modified ARC settings or other plugins.
Do you have any ideas about what might be causing this, or what additional information (for example, whether the camera is connected directly to the PC or through an EZB, or logs) I should provide?
I have verified the Robot Store after restarting ARC with an internet connection as requested.
I am happy to confirm that the Kinect Body Control skill is now visible and I have been able to install it successfully into my project.
Thank you for your assistance and for resolving this issue.
