Com Port Manager icon Com Port Manager — Displays local PC COM/Serial ports opened by scripts, showing open/closed status (no communication logs); not the EZ-B UART. Try it →
#25
The connection method is the same for Windows 8 as Windows 7.
  1. Go to the desktop
  2. Right click on the bluetooth icon in the tray by the clock
  3. Select Add a Device
  4. Power up the EZ-B
  5. Select the EZ-B from the list of detected devices. It may be named Linvor if it hasn't connected before.
  6. Click Next and follow all on screen prompts
  7. Enter the pin code of 1234 when prompted
  8. The EZ-B should be paired with the PC
  9. Open ARC
  10. Select the correct COM port from the list in the connection control (top left of the ARC desktop
  11. Click connect
Your EZ-B should then be connected to ARC.
If there are any errors ARC will tell you.
If the EZ-B currently doesn't have the latest firmware you will need to upgrade the firmware.
Both the pairing method and updating the firmware process are covered by this tutorial I wrote. It is complete with screenshots to aid you however was written over a year ago and therefore the screens may be a little different now, the firmware certainly is.
The method for Windows 8 is no different to Windows 7 if you use the desktop as described above. Windows 8 desktop is pretty much the same as Windows 7 desktop with the obvious exception of the start button/start screen.
#26
wall-e lover360 listen to rich he is 99.9% right only one problem the code could be 0000 but that is not likely if 1234 doesn't work its 0000 other then that rich is right hope that works for you wall-e lover360 and way to go rich
#27
The pin for the V3 bluetooth is 1234
Refer to page 6 of the technical manual;
Quote:
Bluetooth
The EZ-B uses a Class 2 Bluetooth transceiver. The distance is approximately 10 Meters (30 Feet) in most configurations. The distance depends on the computer's Bluetooth module and the amount of shielding around the EZ-B.
Here are the steps to add the EZ-B to your PC's Bluetooth devices...
  1. Provide power to the EZ-B
  2. Within 90 seconds, select Add A Device from your Bluetooth Icon on the system tray of your taskbar
  3. The EZ-B device should appear. It may appear as "Other", so please select it and press Next
  4. When prompted for a Device Pairing Code, chose the option to enter one. The pairing code is 1234 and press Next
  5. The EZ-B will be detected as two COM Port devices. The first COM Port device is the EZ-B data-channel (Lower COM Number). That will be the COM Port that you will connect EZ-SDK and ARC to. The second COM Port is unused at this time as it is reserved for future enhancements (Higher COM Number)
#28
wall-e lover 360, The pairing code is 1234 as D.J. says in the EZ Robot tutorial. I would try the EZB only without any servo connections until you are paired and connected. Make sure you have strong batteries and have the EZB close to your windows machine while you pair. There are many great people that will continue to try helping you. Keep trying when you are able to.
#29
Ok, I'll try to help.
Not sure if the full windows tablet shows the same but I think it does.
  1. If you have the Bluetooth devices button click it and then click "Add device".
  1. Something like this should come up. Click "pc and devices".
2-continued. Click the "Bluetooth tab".
  1. Make sure the ez-b is on, and the red Bluetooth light is flashing and the blue light is pulsing.
  2. Your screen should look like this. If the ez-b is on it should pop up in the device list with the words "Ready to pair" under the name. click it and when it prompts you for a code, type 1234. It should now install stuff for the board automatically.
5.When it finishes, go to ARC and choose a com port available. One wont work. One will work. It might say you need to install new firmware. If it does ask.
wall-e lover 360, Does your EZB board still power up after you heard a popping noise? You mentioned in post #11 "On my windows tablet on bluetooth it shows the ez-b but there is no button that says connect the only button there is forget item "
and on post #18 "It won't connect all it shows is ez-robot(not connected) and remove divice". The actual connect button is on the top left of the ARC software that you will open after pairing, not on the windows bluetooth page that shows "remove device". Today I installed an additional EZB3 on my windows 8.1 After it found the new device, it paired after I gave it the 1234 code, but it did not list the comm ports. I loaded ARC software, clicked on the box next to the CONNECT button (top left), that showed me the possible comm ports. The error box area will give clues on what is happening. After I attempted connection on the correct port, I was prompted to update FIRMARE. I closed ARC, found Program files (86) on my hard drive, EZ Robot, EZ Robot Firmaware Update. Loaded Firmware update, typed in the same comm port that I used above, connected, updated, and recycled power. I would watch the EZ Robot tutorials again then give it another go. Steve S
#31
thanks for helping everyone but I'm just going to get an ez-b v4
