Hi guys I have an ez-b v3 how do I connect it to a Windows 8 pc
wall e lover 360
— Edited
8 Participants
It won't connect all it shows is ez-robot(not connected) and remove divice
its good to have another kid on iam only 11 what are you using battery or a blue vex battery I use aa's and it does(the odd servo sound) that if you are using aa's just change them connect if it is the blue one just charge it the servo sound happens to me to and save up for a laptop it is easier to use hope that helps @wall-elover360 and are you using a controller voice command or keyboard control
Hey man I use rechargeable aa's and I have a full windows 8 tablet that means its just like a pc and I all ready have ez-biulder installed and I know its hard to explained what your talking about trust me it happens all the time but can U try to explained what your saying allitle better I don't quite understand.
Ok, as Alan suggests have you paired the EZb3 with your PC?.... If you haven't paired your EZB with your PC, please read the following...
Before you can connect to ARC you must pair the ezb3 with your PC (laptop).... To do this, turn on your EZB3 then open the Bluetooth control in Windows 8, search for new Bluetooth devices. Once Windows finds your EZB you'll be asked to pair your EZB with Windows. You'll enter the pairing code 1234 then save.
Open ARC and in the connection dialogue there will be a drop down box, select the new port given by windows to your newly paired EZB...there will be usually 2 new ports created, select the lower port number...for instance if you see ports 3 and 4 select 3. If you have more than 2 ports you'll need to experiment to see which one might connect. Bare in mind you might have to cycle the power on your EZB every time you check a new port for a connection....
Hope you get it working....
if your board has been on for a while u most likely fried your v3 was it touching metal if it is no wonder its fried if not I don't know I will half to see it share a video so I have a better understanding I really want to help you please share a video and listing to Richard he can really help he help me a lot
Hey guys I have to go thanx for everything
Please keep at it and let us know how you made out...
hey @richardr
