NMS Faux Odometry icon NMS Faux Odometry — Estimate pose odometry from movement distance for robots without encoders, calibrated by speed. Suited for DIY navigation; pose drifts with lidar. Try it →
Can't Hook Ezb4 To Network
I have an ezb4 that has worked fine for a while. I had took the robot apart and then put it back together using the V4 instead of V3.
My problem is: I go to find the ezb in the internet access window. I have reset it many times.
I have to give it a code 1234 to hook up to bluetooth. well, I found that I lost ports for Com3, and Com4. So I added them back. My device shows up, but I have a hard time getting to the part that says are you ready to pair?
If I enter in the correct number, it goes out a trys to pair it, it times out and I have to start all over again.
The green light is on and it continuously blinks. There is no red, or whatever. Just a blinking green light.
I have taken everything apart and now my time has run out. I will be back Tues CST to work on it again. I have the unit hooked to a separate 12vdc battery so it will have plenty of juice. There is a constant blinking green light.
Also, there is no sound at all.
thanks in advance.
#42
Sweet, glad it's working again. That was fast, thanks Alan. Funny how grown men love robots:D
yes i forgot one,sorry about that.
superduo alan&merne then.
#44
No, no, Alan is the hero here. Alan has help a lot people and has a lot others too. Actually I was hoping my name would not be mentioned but that's OK to.
#45
-- sorry about that @Merne. Didn't realize you wanted to keep the arrangement just between us.
Anyway, your contribution was appreciated.
Hey, Alan. I am hooked up to the network. But, how do I know that I am in the Client Mode?
BuggyEZB is doing fine.
#48
OK, I have watched the videos and followed the procedures. I have hooked a blue LED to light up on D0 to see if it is connected. It is connected just fine.
But, my question was not answered. I asked "How do you know it is in the Client mode?
I have two concerns.
  1. My Router usually uses 10.0.0.1. But now , it is using 192.168.x.x
  2. The EZB4 did not show up in the scan. But it is hooked up and works.
I was looking for an answer like: Solid Blue = Client mode. Solid Red = AP mode.
Thank You , richr
