Sabertooth Kangaroo icon Sabertooth Kangaroo — Movement panel enabling Kangaroo & Sabertooth encoder-based speed/velocity control, UART/PC serial options, tuning and encoder setup. Try it →
Azure Text To Speech, Talk Servo V2 Not Working
Hello All-
Im sure im missing something, but here is what Im working with.
EZ robot head- Azure Text to Speech Bing Speech Recognition with VAD OpenAI ChatGpt
Everything works great but cant get the mouth to move from response "Using speaker from robot head"
Azure selected to use "Speak out of EZB"   If I dont use Azure text to speech it works. Am I missing a variable?
Thank you All.
EZ-Inmoov Robot Head by EZ-Robot & Gael Langevin
EZ-InMoov Robot Head with Synthiam ARCx: face tracking, speech recognition, Talk Servo jaw motion and AI conversation
Servos 8
ADC 2
Digital 8
Talk Servo V2 by Synthiam
Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop.
Azure TTS for ARC robots: generate natural, customizable neural voices for companion, educational, assistive, and entertainment applications.
Hello!
It sounds like you're having an issue with getting the mouth movement to synchronize with the Azure Text to Speech output on your EZ-InMoov Robot Head. When using Azure Text to Speech, the audio is generated and played back, but it doesn't inherently control the servo for the mouth movement. You'll need to create a mechanism within your ARC project to move the mouth in sync with the speech.
Here's a general approach to solving this issue:
  1. Sound servo Control: Use the Sound servo robot skill to move a servo based on the sound output of the computer. This skill will move a servo when sound is played from the computer's speaker. You can find the Sound servo robot skill in ARC by navigating to "Add Robot Skill" and then selecting "Misc" to find the Sound servo skill.
  2. Configure Sound Servo: Once you've added the Sound servo skill to your project, configure it to control the servo that operates the robot's mouth. You'll need to specify the correct port that the mouth servo is connected to and adjust the settings to match the movement you desire.
  3. Test the Configuration: After configuring the Sound servo skill, test it by using the Azure Text to Speech skill to speak a phrase. The Sound servo skill should detect the audio and move the mouth servo accordingly.
  4. Adjustments: You may need to fine-tune the settings in the Sound servo skill to get the mouth movement to look natural. This can include adjusting the sensitivity, the range of servo movement, and the center position.
Remember, the Sound servo skill relies on the audio output of your computer, so make sure that the Azure Text to Speech skill is configured to output sound through the computer's speakers.
If you need further assistance with setting up the Sound servo skill, you can refer to the support documentation for that skill on the Synthiam website: https://synthiam.com/Support/Skills/Misc/Sound-Servo
By following these steps, you should be able to get the mouth movement working with the Azure Text to Speech output on your EZ-InMoov Robot Head. If you encounter any issues or have further questions, feel free to reach out for more help.
#2   — Edited
From the Talk servo v2 manual page
Quote:
This skill will bind to the Text-to-speech engine and move servos to simulate jaw movement when speaking. This skill will move the specified servos to simulate a mouth movement whenever a text-to-speech script command is executed (i.e., Say, SayEZB, SayWait, SayEZBWait). If your robot has servos connected to simulate a mouth, this skill will move those servos while speaking.
It works only with the built-in say commands. However, we quickly changed the talk servo v2 robot skill that will allow you to use it.
Instructions
  1. Update to the latest Talk servo v2 robot skill (https://synthiam.com/Support/Skills/Audio/Talk-Servo-v2?id=19940)
  2. Use the ControlCommand() "speak" and that will speak the text.
// send the azure command here
ControlCommand("Talk servo v2", "Speak", "The text that is speaking");
*Note: I edited your question to include the Talk servo v2 robot skill.
Appending to the previous advice, you can also use the latest Azure Text To Speech robot skill's new options. There is the ability to have the script run the Talk servo v2 ControlCommand for each new time it is speaking.
Put this in the Azure Text To Speech script...
ControlCommand("Talk servo v2", "Speak", getVar("$AzureText"));
#4   — Edited
Thank you very much and Happy Holidays.
I did get Azure Speech to Text to speak and move Talk servo using- ControlCommand("Azure Text To Speech", "speak", "Hello i am speaking to you"); ControlCommand("Talk servo v2", "Speak", "The text that is speaking");
Robot output- Hello i am speaking to you, with mouth moving. Using selected voice from Azure.
Can I script this to speak response from Open AI-ChatGpt and Azure speech to text (selected voice) with mouth moving?
If not I get it but Thank you all for what you do!
Rebooting ARC downloading newest update for Azure text to speech
#6   — Edited
YOU GUYS ROCK !  Its working with Azure text to speech (selected voice) and Talk servo V2 and OpenAI-ChatGpt.
Mouth moving with Speech.
Thank you- what a great Mod/Update. I feel like part of the team.
Cant say ENOUGH. What a great Holiday gift to us All.
Thank you very much for the positive feedback. Enjoy!
