Neopixel Ring icon Neopixel Ring — ARC UI for onboard computers to control NeoPixel rings via serial: test/run patterns, preview and copy Arduino serial commands, includes sample code. Try it →
Amazon Echo Hacks ?
Amazon Echo Hacks ?
Has anyone seen or heard of any hacks to the echo yet? Currently, I have my "personal assistant, Antonn" using Alexa. Key voice commands by him operate her when she can perform better than he can. My goal is a future Alexa voice change to male. I have seen some voice changes done on You Tube but they are beyond my skill level.
Has anyone heard of a voice service offering an Alexa's voice?
I think Alexa will be a great incorporation with an EZ-B in the future. Any opinions?
Ron
#17
A question for Echo owners ( I don't have one yet): when Alexa speaks, does she use the same speaker that provides the sound for streamed music, or does she have a separate speech output/speaker? I have an (inelegant) idea for voice modification, but if the sound output is common to speech and other sounds, it won't work.
Thanks!
#18
Same speaker for everything in the echo dot. Ive been experimenting with live voice changers that change pitch and gender. But run into the issue you are bringing up , if you want to play music, be prepared for some interesting results :/
..and all your robots will be named Echo, Alexa or Amazon...
#19
They just added "Computer" as a name.:)
Using a voice modifier was what I was going to try, so there goes that idea out the window. Unless there's a filter switch that could turn the modifier on or off when the voice engages.
#20
In my best Scotty voice , " computer on..."
#22
One of my favorite scenes from ST IV. :D
#23
Has anyone done more with Alexa ? I continue to transfer commands from my robot to Alexa for weather, music, radio, news, setting timers or alarms but that is it.
