Wowwee Rovio icon Wowwee Rovio — Movement panel integrating WowWee Rovio with Synthiam ARC for remote drive, live camera, audio and docking control. Under development. Try it →
ARC Revolution Error When Downloading A Robot
Hello,
So I am trying to sync my library so I can download some 3D printable robots but I am getting this error:
Downloading library index... 12 EZ-Bit identities downloaded Comparing against your library... Download 12 EZ-Bits... (This may take a while)
1 of 12) Downloading JD Biped Body by DJ Sures (2,292,276 Bytes) Error downloading from EZ-Cloud: The formatter threw an exception while trying to deserialize the message: There was an error while trying to deserialize parameter https://tempuri.org/:GetEZBitResponse. The InnerException message was 'There was an error deserializing the object of type EZ_Builder.com.ezrobot.www.bits.GetEZBitResponseBody. The maximum array length quota (16384) has been exceeded while reading XML data. This quota may be increased by changing the MaxArrayLength property on the XmlDictionaryReaderQuotas object used when creating the XML reader. Line 4, position 191334.'. Please see InnerException for more details.
#25
Ah ha, I have 4.0 on this (32bit W7 Ultimate). Desktop has 4.0 (W7 64 bit) Laptop (Win8) has 4.5
.net 4.5 download
Will update once .net is updated:)
Will everyone please stop downloading .NET 4.5 its slowing down my download :)
ok finished now hehe
#28
Haha so now that I got that issue fixed I can move onto the actual issues of how do you configure and print the robot?
I can see how you can manually build your own robot with parts from the library but isn't there an option to just use the pre-built design, only setting up your custom servo ports?
I am trying to make JD the bi-pedal robot in the design area. I just dragged out all JD parts except for the arms. I am not sure how to make the arms? Isn't there a way to just select a pre-built robot to print?
#29
Oh i just read DJ's post, look like they might be under examples...
ok well i cant get the .NET Framework 4.5 to install at all and i did every thing it said to do but no go so i guess its just another thing i need to buy a new computer for:(
soon i will be compleatly left behind in all the fun lol
#32
You'll still be able to buy from the store dude, JD and hexapod will be for sale from what I gather. No need to 3d print or modify files. And I am assuming your PC isn't going to be the best for making your own 3d files.
