Cognitive Emotion icon Cognitive Emotion — Uses Microsoft Cognitive Emotion cloud to analyze camera images, returning emotion descriptions and confidence for speech/output (requires internet). Try it →
ARC Revolution Error When Downloading A Robot
Hello,
So I am trying to sync my library so I can download some 3D printable robots but I am getting this error:
Downloading library index... 12 EZ-Bit identities downloaded Comparing against your library... Download 12 EZ-Bits... (This may take a while)
1 of 12) Downloading JD Biped Body by DJ Sures (2,292,276 Bytes) Error downloading from EZ-Cloud: The formatter threw an exception while trying to deserialize the message: There was an error while trying to deserialize parameter https://tempuri.org/:GetEZBitResponse. The InnerException message was 'There was an error deserializing the object of type EZ_Builder.com.ezrobot.www.bits.GetEZBitResponseBody. The maximum array length quota (16384) has been exceeded while reading XML data. This quota may be increased by changing the MaxArrayLength property on the XmlDictionaryReaderQuotas object used when creating the XML reader. Line 4, position 191334.'. Please see InnerException for more details.
Just tried again, I can't download anything or see any 3D printable parts because of this error. Anyone else having this error? Or is the sync library button working for you?
Hi, feroze, yes I'm having the same error. You're not alone.
Steve eyeroll
It's the same issue with the cloud which DJ addressed earlier. Frustrating I know but hold out until they can fix it.
ah ok, well all I really care about is that it is not just me. Having an issue that only your computer is dealing with is the worst!
Nope me too:( You are not alone;)
I noticed this in the code.
.com.ezrobot.www.
wouldn't it be ez-robot.com with a hyphen? I know it says its a size issue but going to ezrobot.com goes to nowhere so I'm assuming anything to do with that name wouldn't exist either.
Also is there a way we can download the bits externally then put them into the proper folder?
Not sure if it's because I just changed computer or not but downloading the library is working on my laptop. It may pay to give it another try.
Edit: Spoke too soon... got a timeout this time on JD's Feet
Another Edit: It works on my Windows 8 Laptop but fails on my Windows 7 desktop. Windows 8 laptop has got 6 of the 12 downloads so far, it fails with timeout on the 4th part (JD Biped Right Foot) sometimes and other times on the 6th (JD Biped Foot and Ankle). Each time I restart the sync it redownloads all 12 (or tries to).
Are you getting the MaxArrayLength error on windows 7 or windows 8?
Only on Windows 7 for me. Windows 8 times out only.
Just checked what it had downloaded on Win 8 and the folders were mostly empty. 1 and 3 had some files (I wont try and write the filenames), folders 4, 5 and 6 all empty. no folder 2.
Update: Windows 8 finished the download/sync OK now, all working. Windows 7, still the error above. Not sure if it's OS related though but that's the main difference between the PCs.
