Robot Skill To Camera icon Robot Skill To Camera — Capture a robot skill's display and stream selected area as video to a configured camera device with FPS and live preview crop. Try it →
ARC Revolution Error When Downloading A Robot
Hello,
So I am trying to sync my library so I can download some 3D printable robots but I am getting this error:
Downloading library index... 12 EZ-Bit identities downloaded Comparing against your library... Download 12 EZ-Bits... (This may take a while)
1 of 12) Downloading JD Biped Body by DJ Sures (2,292,276 Bytes) Error downloading from EZ-Cloud: The formatter threw an exception while trying to deserialize the message: There was an error while trying to deserialize parameter https://tempuri.org/:GetEZBitResponse. The InnerException message was 'There was an error deserializing the object of type EZ_Builder.com.ezrobot.www.bits.GetEZBitResponseBody. The maximum array length quota (16384) has been exceeded while reading XML data. This quota may be increased by changing the MaxArrayLength property on the XmlDictionaryReaderQuotas object used when creating the XML reader. Line 4, position 191334.'. Please see InnerException for more details.
#33
Not sure what .net my desktop is at but my laptop is 4.0 so, I'm going to delete the files then try again after 4.5 installs. I'll post results.
I click on EZ-Bits, Library, Sync now which I presume is correct?
.NET 4.5 didn't work for me I get this message
Downloading library index... Error downloading from EZ-Cloud: There was no endpoint listening at https://synthiam.com/Community/Revolution/WSRevolution.asmx that could accept the message. This is often caused by an incorrect address or SOAP action. See InnerException, if present, for more details.
Might be something to do with webpage naming
This web service is using https://tempuri.org/ as its default namespace.
Recommendation: Change the default namespace before the XML Web service is made public. Each XML Web service needs a unique namespace in order for client applications to distinguish it from other services on the Web. https://tempuri.org/ is available for XML Web services that are under development, but published XML Web services should use a more permanent namespace.
#35
And .net 4.5 is what was needed. Working perfect now.
It also solved the cloud problem I was having and mentioned earlier:)
yes i could buy the parts but if i cant dl the files into the program i will not be able to see how thay go together or any of that other stuff so i will need a new computer before i can part of the revolution ive tryed looking at it but nothing shows with out the files
#37
I'm successful on Win7Pro32 after .net update from 4 to 4.5:)
OK Windows 7 machine 64 bit OS and .NET 4.5 works Laptop Windows 7 64 bit OS .NET 4.5 errors
Go figure?
