EZB Connect By Name icon EZB Connect By Name — Discover EZB WiFi controllers by name, auto-bind connections, avoid IP management; live discovery and multi-EZB support for ARC. Try it →
ARC Revolution Error When Downloading A Robot
Hello,
So I am trying to sync my library so I can download some 3D printable robots but I am getting this error:
Downloading library index... 12 EZ-Bit identities downloaded Comparing against your library... Download 12 EZ-Bits... (This may take a while)
1 of 12) Downloading JD Biped Body by DJ Sures (2,292,276 Bytes) Error downloading from EZ-Cloud: The formatter threw an exception while trying to deserialize the message: There was an error while trying to deserialize parameter https://tempuri.org/:GetEZBitResponse. The InnerException message was 'There was an error deserializing the object of type EZ_Builder.com.ezrobot.www.bits.GetEZBitResponseBody. The maximum array length quota (16384) has been exceeded while reading XML data. This quota may be increased by changing the MaxArrayLength property on the XmlDictionaryReaderQuotas object used when creating the XML reader. Line 4, position 191334.'. Please see InnerException for more details.
My Win7 school laptop is still getting the original length error of the first file. I'm still at school for a couple of hours. I'll try my home Desk and Laptops ASAP and give any info I get. Both are Win7 but my laptop was cored a few days ago to be primarily my ezb command center so maybe I'll have some better luck. I also could be having issues with the schools internet. I'll post when I get home.
Interesting. Okay ill take a look to see what difference windows 7 has. As for the timeout, that'll be an easy fix. Update coming soon:)
That's beta for you:)
Just checked on my other Windows 7 PC and it throws the same error so most likely an OS issue.
On the plus side, I cheated and copied the EZ-Bits over from the Windows 8 to the Windows 7 PC and that worked so once on Win 7 it's all OK.
I've paid good money for buggier software;) Isn't this why you have betas?:)
I to got the same error thought it maybe because i only have win xp ?
@Rich, I was going to do the same when I got home. My Sister in law has win8;) Glad to know it worked. I'm also cool with helping troubleshoot bugs in beta. I'm a beta tester for the Xbox360 Dashboard so bugs are just a part of life to me.
I was using Win 7 when I had the issue
#15
I'd say it's a win 7/win xp issue then since that's 2 win 7 and 1 xp for me that it happens on.
Out of interest, has anyone else had sucess with Win 8?
United Arab Emr
#16
I used my vmware machine on my Mac with windows 7 x64 . Installed .net 4.5,the ARC new version , sync and it started downloading almost finished 5 files....9 files ....11 files
