Sharp IR Radar icon Sharp IR Radar — Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel Try it →
#1   — Edited
You noticed wrong, sigh.... SayEZB works perfectly with an iOTiny... Maybe try plugging in the speaker on your ioTiny....
Are you using the latest ARC software?
RR i have the speaker plugged in as usual,sight
ptp
 yes the latest version.it worked with the previous version.
Works just fine for me... You are either doing something wrong or you have a hardware defect. My money is on the former....
RR
i can hear the connection chime ,and say i have connected to your network . as i said it worked before.
thanks anyway
So what changed since last time ?
ptp
nothing i use as i do it like always.but now it doesn work. see picture.it looks the error prefer to a object?
#8   — Edited
Tested Video... I will be deleting this soon so have a quick view while you can...
