Reboot the PC Open the Room Windows (to get some fresh air) Open ARC Check if there are no new updates Connect to IotTiny Close the Room Windows (It's getting too cold) Create a new Script (EZ-Script) with
SayEZB("Hello")
Run the script Share the results
reboot pc did the trick. thank you ptp
#11   — Edited
If that does not work my #2 is to open the room windows  and my #3 is to get out for a walk
i cant open a window its raining.i live on the atick. what you mean take a walk?
#13   — Edited
after that... oh boy:
Is anyone able to reproduce this error? It does seem like something weird happened. The console shows a reference not set to an instance of an object.
nomad, any idea how to reproduce the error?
#15   — Edited
I tried old, new projects, existent JD projects, connected, disconnected... no luck
#16
Okay thanks ptp. I’m scratching my head as well. Boy, wish computers were more logical:) hahaha
