#89
The cloud apps have been updated to the most recent:)
#90
I do not know what you mean by "his left and right arms are different". His left and right is the same as your left and right. Also, make sure you have the latest app that is in ARC.
Left is on the left side of your body. Right is on the right side of your body.
so pic from d.coran is correct?
mine shows D4 there. What version of the ARC software are you running?
as you can see the latest version.2014.09.19.00
#94
Its wierd that it shows up on mine but not yours. Anyway, the information you listed earlier is correct. You should be all good. Let me know when your ready to get this guy on your network and I will do what I can to help you with that.
#95
nomad, it appears your project is out of date for some reason. During a re-install the project should be updated. It doesn't appear to have been updated. Perhaps you will need to get it from the cloud or reinstall ARC.
i just reinstall ARC.
in the assembly says R arm D8_D9_D10 LEFT D?_D6_D7
