Lynxmotion Smart Servos icon Lynxmotion Smart Servos — Compact Lynxmotion Smart Servos with position feedback, safety features and UART TX/RX for Arduino/EZ-B v4; scriptable temp, load, load-dir and ping. Try it →
Webots Implement To ARC
Dear dj I'm not sure if ARC has a 3d map genetator for programmable task because I haven't got to use the ARC software, but if not i would like to know if webots software can be implemented with ARC by downloading or if it can't be I would like to see future implementation with ARC . I know that ARC has a EZ-Script writer, but I am wanting to create a 3d generated map layout of my house like robotis of korea does with darwin-op, so that my robot omega is able to explore and do task that I script for him. That way instead of seeing just object detection but also know my house like I do. if ARC has this type of software installed with it, then I fell pretty stupid lol
Guess we will just have to set up a direct deposit from our paychecks to EZ Robots:D
Lol dang rite now if only I was able to do that I would have a house full of ez-robots lol
@Dj can you confirm the size of the new EZB camera. Is it the same size....Gawd i hope so...
The other thing we could potentially be able to figure out with two cameras is depth perception. Make object tracking and finding much more accurate.
@fxrtst I can confirm that the new camera will fit in the existing camera enclosure and JD's head, if that helps.
Inverted Pendulum robots must consume alot more battery power to constantly be updating position and orientation. The motors must be active all the time?!
#15
Depends on how well the robot balances to begin with - You could build a low center of gravity so it has a fairly wide "sweet spot", but yeah, I suspect so.
#16
@jeremy, Thanks that helps a lot! ( wipes sweat off brow)
