Cognitive Vision icon Cognitive Vision — Microsoft Cognitive Vision integration for ARC: real-time object, face, emotion detection, OCR, confidence data and script-triggered robot actions. Try it →
remove start and goto?
#42
Patrick, it's a script, just press STOP like very other scrip in ARC, I've seen you do that in your videos I know you know how to press stop to stop it from running like any other script and it will stop sending email pictures to you.
Or are you trying to ask how to modify the script in order to change it's behavior so it does something else for you?
ah i placed the script in the camera script,not separt. so i make a script outside camera settings.?
got it use the pause button.
#45
Yes, you should always keeps your scripts separate from your controls unless you have a very good and specific reason to put them in the control settings of your control objects.
That was a good example of why you should NOT put a script like that there.
I recommend using Script Manager(s) to organize your scripts, then you can manually start and stop them. You can also create voice commands to start and stop your scripts. And if you get fancy you can use personality generators or versions of AI to let your robot choose when to run it's own scripts.
I think you learned a lot today Patrick!
justin
yes indeed.the finding of the smtp on telenet alone was super, i finaly found something.ofcourse with some needed help here,:P ok i changed to a separt script,and still works. i will see what the script manager does.
thank you very much.
now its working on my phone to,inclu the pic too .awesome ;) its works really fast,the sec jd notest movement its comming allreddy , in my phone.
This has been an interesting post. I learned something. Glad you got it working Nomad
