MP3 Trigger icon MP3 Trigger — Serial MP3 Trigger for EZ-B: plays MP3s from mini‑SD; configurable port/baud. Deprecated-replaced by EZB v4 streaming audio. 3rd‑party. Try it →
Resolved Resolved by Perry_S!
Speech Recognition not working in Windows 10
Speech Recognition Not Working In Windows 10
Can someone help me with getting my speech recognition to work in Windows 10 on my new PC?  It works fine on an older windows 8 PC that I had been using.
I added the microphone control to the project to make sure that it hears the microphone.  That works.
In the speech recognition configure menu, when I speak the levels tab on the side goes up and down.  So the microphone seems to be working.  I'm using an external microphone.
There isn't a line readout in the speech recognition control in the upper right corner as there is on my windows 8 version.  So I don'tbelieve the module is connecting  to the speech recognition part of microsoft.   No confidence number or anything.   This is what my project looks like:
When I open microsoft word, I'm able to get the dictation working.  So I believe the speech recognition part of microsoft works, but it doesn't appear to connect to ez-robot.
Any help would be appreciated.  I've been struggling with this for a few days.
#33   — Edited
in the link from dj says after check on ,close and reopen app.
here it says only reopen app.but its possible you have to reboot
#34
Hmm, I checked that the ARC can access the microphone.  Also rebooted as fxrtst suggested.  I'm still not getting either of the speech recognition modules to work.  The microphone does see wave patterns.
the lower speech recog is not complete.i would delete bolt and take a new window.
#36
@bigjake, did you turn off the "on" slider and turn back on?
#37   — Edited
Deleted......................................................
#38   — Edited
Maybe turning it off and on?
the microphone control doesn’t use the same libraries as speech recognition control. The microphone control talks directly to the device. However, the speech recognition control uses the builtin Microsoft Windows speech recognition library and that’s the trouble. It’s because the speech recognition system is separate from ARC and built into windows.
We’ll figure it out:)
#39
I've moved the switch back and forth.  when I remove the microphone control the ARC and Speech Run Time aren't in-use.
#40   — Edited
Correct. Now try to reboot and open ARC and see if you have the wave.
