Hello,
I try to install the ez buider on my android V4.1.2 and I get a signature error, do someone know what to do ?
Thx a lot
EZMQTT Client
— MQTT client for ARC: connect to brokers, publish/subscribe topics, map incoming messages to variables (incl. binary arrays) and run scripts.
Hello,
Thx a lot
I just re-installed on v4.4.2 with no problems. So maybe it's a OS version issue then. Ideally we need someone to reinstall the app on v4.1.2 to confirm if it is a version issue or not. I can't think what else it could be.
I've seen and try it (clear cache) with no success.
The other links I found lead to something that DJ will need to fix in how the application was signed or in the java version installed on the machine where it was compiled (although that seems to be an old problem when Java 7 was new).
traxx same here signed error
Nomad, what'S your version Android and OS ?
Java is great but make so many probems.
android sony experia 4.04
@nomad.
What Android version are you getting the signed error with? Is it v4.1.2?
so it happen on differents versions of android...
