Hello,
I try to install the ez buider on my android V4.1.2 and I get a signature error, do someone know what to do ?
Thx a lot
Stepper Servo
— Control up to 127 stepper motors via Arduinos mapped to ARC servos; supports any stepper driver, serial network, home calibration, speed/accel.
Hello,
Thx a lot
Are you trying to install ARC Mobile ?
V4.1.2 is compatable so no worries there. I would suggest deleting the version you have on your android at the moment, then reinstalling it. Don't know where you downloaded it from, but try downloading it again from Google play, or directly from EZ-Robot. The link below which has choices for both.
synthiam.com/Products/ARC
And here's the link for the Android download tutorial that may help you too incase you havn't read it yet. Hope it helps.
synthiam.com/Tutorials/Lesson/60
Thx a lot for quick answers.
Yes it's for install on a mobile with android 4.1.2
I'ven't be able to install it, I've try both way ( Google play and direct from EZ-Robot)
The exact error message is: " the signature of file of package is incorrect" and I've no choice to clik on "OK".... no more information, I can try to reinstall and get the same error.
I've already reinitialize the phone from factory setting and get the same error... tired
Thx agian if you have another idea...
It isn't on Google Play yet. You need to download directly from here.
Signature error was happening on Android versions earlier than 4.2 but DJ re-compiled for anything 4.03 and above (I think that was what he set as the minimum) and re-posted a month or so ago, so it should be working. Signature error is what you get if you don't meet the minimum version requirements.
Ok, it's all my fault, I have androide V 4.1.2 and OS V 3.0.31..
So I can't use it... stress
Thx for your answers and time.
It should work on v4.1.2. I also searched for the error, and it is not signature error if the version is wrong, but parser error, so what you are experiencing may be something unrelated to the version.
Do you have your Android set to allow install from unknown sources? (settings, security).
here is the link ARC in google play
app
Yes I've already set it to accept unknow sources... tired
