Kinect Body Control icon Kinect Body Control — Control robot servos with Microsoft Xbox 360 Kinect body tracking; map joints to upper/lower body servos with smoothing and pause control. Try it →
also DJ does also the IROBOT CREATE work with EZB,it uses the same board as roomba 4000 series only has connection to a 25 pin DIN plug and I/O pin,SCI COMMANDS almost the same,just a few more features
Fred,
I can answer that. The create works fine with D.J.'s cable with only two pins connected, Signal and ground. The roomba Movement Panel works fine connected up to the EZB.
Mel
mostly i want to know from DJ is the output connection 25 pin DIN connector from the control panel only a few buttons,where the 25 pin as much much more plus there is no output ,for sensor data witch is very usefull on all roomba's and create models
