Set Digital icon Set Digital — Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only. Try it →
Netherlands
Twitter YouTube
#25
Not at the moment, but you can download the design file by clicking 'User Details' under my profile picture and going to 'EZ-Bits'.
i will try that .thank you is the 3d print only availeble in sdk?
Netherlands
Twitter YouTube
#27
I've attached the STL file to this post. You can import it in the bit builder to use it in ARC. Most 3d-printer software also supports STL files.
Adaptor.STL
thank you very much niek
#29
You're going to have to 3D print a bigger chest aswell. As you may know, there are two servos cased inside of the chest that move the arms up and down. :)
i dont have a 3d printer. i cant open file from niek eather.
Netherlands
Twitter YouTube
#31
@nomad
To use the file in ARC you go to 'Project', 'Bit Builder' and click 'Add STL'. Since you don't have a 3d printer, you could use a service like shapeways and have them print it and ship it to you.
yes i saw that. i seen on the by page here.the top off rolli is separt to by but the bottem is not separt to by.
