Live Stream Receiver icon Live Stream Receiver — Play live web video and audio streams inside ARC from Chrome/Firefox, streaming directly to ARC camera control; network configuration may be needed. Try it →
is parts waist JD and under body to by ?
I used the Rover base in bodies to substitute for the treaded track. and put the rover cover on top of it. The body os the jd biped body.
#19
Well, that's quite a plan you have there. I'm fairly certain that the JD-to-Roli body EZ-Bit isn't available yet, but maybe soon. (they probably still have the 3D model):D
#20
The JD body will slide in where the camera servos are attached.:)
#21
The JD body has two female connectors, and to make it worse the roli body has a female connector on the part he wants to click it on to. The robot in the picture is using a 3d-printed connector (designed by niek, if I remember correctly).
yes thats correct.
Netherlands
Twitter YouTube
#23
Wow, that IS my adapter:D
yes it looks very good on the rolli.is on sale?
