Screen Recorder icon Screen Recorder — Record your screen to WMV1/WMV2/H263P files with selectable bitrate, save-folder and start/stop controls, creating tutorial or demo video snippets. Try it →
#57
Yes J, if you have the time. I am going to keep trying different things to get JD working on my HP before I switch to a different computer! Thanks.
#58
i will go through the steps then video it. Give me an hour or two to do it.
j
p.s. I will work on jd after, just finished six, that gives me 4 v4 robots and one v3 robot.and another ships next week. jad
:D
#60
I would suggest uninstalling your current drivers and replacing them with a Microsoft one or a different one. Sounds like a driver problem.
#61
@technopro
they are hp and ms latest drivers for me.
only one other thing, i tried before start to connect to ezb.
From an Command Prompt (Admin) type
ipconfig /flushdns
j:D
#62
Mike,
This my work for you!
Change Network Interface Card (NIC) Priority in Windows
Question How do I change a network card's priority in Windows? Answer You need to ensure the network cards are in the correct order of preference in which the connections are accessed by network services. To change the priority (or binding order) of network cards in Windows when multiple NICs are on a machine, follow the below steps:
  1. Select the Start button and click Control Panel.
  2. Click Network and Sharing Center.
  3. Click Change adapter settings to open the Network Connections window.
  4. Press the Alt button on your keyboard; a hidden menu will appear beneath the location bar.
  5. Select Advanced | Advanced Settings. This window displays the order of preference in which network connections are accessed by network services.
  6. Select your Local Area Connection within the Connections section of the Adapters and Bindings tab. You will see current connections listed in the order in which they are accessed by network services in the Bindings for Local Area Connection section.
  7. Use the up and down arrows to the right to change the priority of the network cards. The network card that connects to the trading environment must be listed first.
  8. Click OK.
After the above changes of bindings for local area connection, the trader’s network card remains as first priority in the connection list.
J:D
#63
Thanks J. Still no luck connecting. I have a d-link router with netgear Wifi USB. When I turn on JD, sometimes I get a Linksys network & sometimes I get a default network but never the EZ B4 network. I'll keep trying. Thanks again.
#64
mike,
Just for fun... Turn off your router. And see if you can connect to EZ-B v4 jd.
J p.s. I am in the middle of resetting up my home network, changing security. jad
