Hi,
I just received my JD but can not connect it to the WIFI with my HP computer. To see if it was an issue with the EZ-B I tried to connect it to my Mac Air and it connected. Does anyone know what the issue could be?
HMC5883 Compass
— Reads HMC5883 3-axis compass via I2C and updates EZ-Script variables on demand; polled control offers periodic heading data, for connected sensors.
Hi,
Richard it is a long answer.
I would tell them and they can write up an how to do it. I am not the best at writing... lol
This is only a work around solution for hp/compaq owners who have two nic's, one a wired connection and second one is a wifi nic, connection. DNS is getting confused when trying to find the EZ-B. And it times out. Says unable to connect.
It requires that they disable the wired connection and the wifi connection. Maybe you could write it up?
Also requires that they have or purchase a usb wifi for their hp/compaq personal computer OR use another pc or laptop to set the EZ-B in client mode.
I have test this on my HP system and it worked. But I need another person who has an HP/Compaq to try the work around.
J
Sorry, I don't know how to take a screenshot. About my Qualcomm Atheros AR9485 802.11b/g/n Wifi Adapter
Advanced
Property: 802.11b Preamble AdHoc Mode Network Address Receive Buffers Scan Valid Interval Transmit Buffers
Value: Long & Short Long Only
Driver
Driver Provider: Qualcomm Atheros Communication Inc.
Driver Date: 5/16/2013
Driver Version: 10.0.0.251
Digital Signer: Microsoft Windows Hardware Compatibility Publisher
Thanks again Michael,
What are the values for 802.11b Preamble (long and short?) and AdHoc Mode (disabled?)
Have you tried to Update your Driver for your WiFi Adapter? (right click on Qualcomm Atheros AR9485 802.11b/g/n Wifi Adapter in the device manager and select update driver)
What version of windows do you have? Is it 32 or 64 bit?
In the Device manager are there any yellow exclamation marks on your WAN Mini-port network adapters?
For the last check you may have to select the View tab in the Device Manager and click on "Show Hidden Devices"
Michael, for screenshots in Windows 8, follow these directions
Press the Windows Key + PRNTSCREEN buttons together. On a laptop, PRINTSCREEN can be labelled PRTSC and is normally located on the top right near the delete key
The screen will flash when you press that key combination
In this forum, press the ATTACH FILE -> BROWSE button. Navigate to your My Pictures folder and look in the SCREENSHOTS folder
Select the screenshot that was saved
Press the UPLOAD FILE button on this forum
Type your message
Press the REPLY button to submit your post
I just updated my driver. 802.11b Preamble - Long & short AdHoc Mode - 11b Operating system - Windows 8.1, 64-bit No exclamation marks Cannot find any hidden devices router is not taking my password in ARC.
Can you explain what you mean by "router is not taking my password in ARC"?
I put in 192.168.0.1 on the first connection. I then hit the round button to go to client mode & my d-link comes up wanting to know my password. When I type in the password, it will not take it. I'm going to try resetting the password tomorrow. Maybe I'm using the wrong password.
