Sharp IR Radar icon Sharp IR Radar — Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel Try it →
Question On Playback Rates
Ok im having a head scratcher today. I connected Alan and Alena up to different laptops to run them simultaneously. One is an older Apple Mac Pro with bootcamp and Win 7. The other is an asus PC Laptop Win 10. Both are i7 quadcores both have 8 megs ram. Both are connected to the EZB via serial/usb using a osepp FTDI. Both are in maximum mode under power options:
BUT The Asus is running my recorders at half the speed as my Mac Pro. I have tried rebooting, changing com ports etc. I've killed and rebuilt animations with recorder, same issue no change. No background programs running either. Alan looks like he is in a slow motion movie "noooooooooooooooo"
When i move the robot over to the Mac running Win 7it runs at perfect speed as it should.
Question is:
What should I be looking for on the Asus that would be slowing down the data?
#26
Brilliant ! Brilliant ! Brilliant!
#27
Does that mean it worked?
#29
That’s great to hear the voodoo works. To keep the conversation in the same thread, I removed the other.
#31   — Edited
...I'm having the old problem with the servo recorder plug in, where it played back at different speeds on different computers. I have not had that problem since DJ fixed it by recording servo positions. I opened a file with servo recorder on it from last year at CES. Playing it on a different computer than I recorded it plays back super fast like the old issue where the plug in was recording data and not servo positions. Can anyone else confirm this?
My main concern is recording all the servo animations for the bartender robot on my laptop computer and then sending it over to the latte panda and having it playback at different rate.
