Please add the little sensor protector to your store.
And What is it called? I see a regulator and two caps. But, what would you call it? Where can you buy it? How much does it cost, Please.
TCP Clients
— Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections.
@mel do you have a link to what you saw. Do you think you are referring to online 5 volt regulators they demonstrated? You can use one of your voltage regulator boards to power several sensors down to 5 volts from your battery voltage.
Hey, that is a good idea. You are so Brilliant!
I would like that also. I placed an order for the EZ-B v4 about a week ago and would like that voltage adapter shield thing added that order. Once it's available online I'll add it.
Thanks,
Bill
@EEGbiofeedback If you ordered a developers kit, I was told yesterday that it will include one to protect the ping sensor, and the included servos don't need it. If you ordered just the board, you will probably need to order one.
Where? How much? What is it Called?
Thanks Alan,
Just ordered the board, and other odds and ends.
Bill
It's not in the store yet and it doesn't really have an official name but I'm it calling the "5V regulator board"
It's pictured in this post.
Any idea when its supposed to come out?
