Live Stream Receiver icon Live Stream Receiver — Play live web video and audio streams inside ARC from Chrome/Firefox, streaming directly to ARC camera control; network configuration may be needed. Try it →
New Help With This Script
I am looking for a little help to finish off this script. The script as it is works, however, I want it to speak the sum of the 2 numbers. I have tried a few different ways but I can't get it. Hey, I pretty proud of getting this far with it. I've made a comment in the code of what I want it to say.
:start
$heard = "speech"
WaitForChange($heard)
if($Heard = "won")
$x = 1
Say("one")
elseif($heard="two")
$x = 2
Say("two")
endif
if($heard = "plus one")
$y = 1
Say("plus one")
elseif($heard = "plus two")
$y = 2
Say("plus two")
#print($x + $y)
EndIf
if($heard = "what does that equal")
#This is where I want it to say something like "$x plus $y equals the sum" or
for example "1 plus 2 equals 3" (if those were the numbers it heard)
print($x + $y)
Endif
GoTo(start)
As always any help is appreciated, Thanks
Are you using WaitForSpeech somewhere in another script? After the WaitForChange you have only 2 choices... I think you need a 3rd so in case the waitforchange does not get either of your response's it immediately skips back to start.... No sense going further and getting stuck on the next waitforchange
:start
$heard = "speech"
if($Heard = "won")
$x = 1
Say("one")
$x = 2
Say("two")
else
say("sorry, didn't hear your response correctly")
GoTo(start)
endif
$y = 1
Say("plus one")
$y = 2
Say("plus two")
#print($x + $y)
else
GoTo(start)
EndIf
$answer= $x + $y
Saywait($x + " plus " + $y + " equals  " + $answer)
print($x + $y)
Endif
GoTo(start)
This is how I would do it:
$sum = Abs($x + $y)
Say($x + " plus " + $y + " equals the sum " + $sum)
Abs is the math function and you can do basic math with it like add, subtract, multiple and divide.
I shouldn't have posted this thread so late at night - The title should have read "Need help with this script", anyway, you guys understood what I meant. @JustinRatliff Thanks that worked. I was so close once. @Richard R Thanks, Ya I have to put what you suggested in the script. I'm building it step by step, there's lots more to go in to it.
@bhouston.... No problem ... I am sure I will be asking you question here and there about your inmoov build... I have just taken the plunge and begun building my own.... Speaking of questions... here is a quick one.... Are you using the HK15298 servos in the forearms for the fingers and wrist rotate?
@Richard R I used HS-311 and MG996R for the fingers and wrists. They were readily available. Email anytime at [email protected] If you have questions and don't want to post them here.
I am writing some math scripts, I've got addition and subtraction figured out . For multiplication I've tried -
$x=2
$Y=2
print ($x x $y)
Doesn't like the "x" in there. What symbols should I use for multiplication and division. Thanks
