EZ-SLAM icon EZ-SLAM — Creates a map in a global variable; proof-of-concept SLAM visualizer (very experimental). Try it →
Do you have a link to the tutorial that you're referring to? Who made the tutorial? Where is it? Etc...
This may be a silly question, but did you read the description of the tutorial which bob made? He has listed requirements. Does your environment meet those requirements?
Also, you didn't include an error message that you're receiving.
I'm sure bob may chime in if he's around. But I'd start by reading the description and following the requirements that bob documented in his tutorial.
Yes that is the correct tutorial and I did read the description. I also have experience using the neopixel ring with MRL with a satellite arduino.
I am going to work on it a bit tonight and I will post more info with the specific errors I am receiving.
Excited to get this going because once it is that means that in a little over 1 month after receiving my EZB with no knowledge of it and being an amateur coder I will have recreated all of the MRL functionality I had after a year of working with that. And it actually works now.
That's amazing news - you're a poster child for ezrobot! Let's keep this momentum going
As for the errors, share them and we'll get you running asap
That's awesome @Perry... Too bad we can't get Gael himself on board with ez robot... Think how much further the inMoov project could advance over MRL...
@Richard R Build it and they will come.
OK, still no luck for me. I downloaded the recommended Arduino version 1.6.3. Wen I try to compile the sketch here is what I get.
Arduino: 1.6.3 (Windows 8.1), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch_jun14a.ino:33:1: error: expected class-name before '{' token
sketch_jun14a.ino:224:1: error: expected '}' at end of input
sketch_jun14a.ino: In constructor 'NeoPatterns::NeoPatterns(uint16_t, uint8_t, uint8_t, void (*)())':
sketch_jun14a.ino:51:2: error: class 'NeoPatterns' does not have any field named 'Adafruit_NeoPixel'
sketch_jun14a.ino: In member function 'void NeoPatterns::Update()':
sketch_jun14a.ino:65:20: error: 'RainbowCycleUpdate' was not declared in this scope
sketch_jun14a.ino:68:20: error: 'TheaterChaseUpdate' was not declared in this scope
sketch_jun14a.ino:71:17: error: 'ColorWipeUpdate' was not declared in this scope
sketch_jun14a.ino:74:15: error: 'ScannerUpdate' was not declared in this scope
sketch_jun14a.ino:77:12: error: 'FadeUpdate' was not declared in this scope
sketch_jun14a.ino: In member function 'void NeoPatterns::Increment()':
sketch_jun14a.ino:103:22: error: 'color' was not declared in this scope
sketch_jun14a.ino:104:8: error: 'dimColor' was not declared in this scope
sketch_jun14a.ino:104:8: error: return-statement with a value, in function returning 'void' [-fpermissive]
sketch_jun14a.ino:109:1: error: a function-definition is not allowed here before '{' token
sketch_jun14a.ino:115:1: error: a function-definition is not allowed here before '{' token
sketch_jun14a.ino:121:1: error: a function-definition is not allowed here before '{' token
sketch_jun14a.ino:128:1: error: a function-definition is not allowed here before '{' token
sketch_jun14a.ino: At global scope:
sketch_jun14a.ino:224:1: error: expected unqualified-id at end of input
Error compiling.
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
Any ideas?
