Camera Click Servo icon Camera Click Servo — Interactive camera control for ARC: click-to-center and edge hotspots to pan/tilt servos, adjustable fine-tune and multi-camera support. Try it →
Mobile EZB And USB Connection
Is it possible for EZB-mobile have support for USB connection?  My robot has an embedded pc with USB connection at the moment, but I would rather use something smaller if possible.
I had problems, in the past, with WiFi dropping connection or struggle to gain connection in large crowds. I settled with an embedded computer for the last 1-2 years.
The robot is often out with large crowds so safety / dropping connections is the biggest concern.
Thank you for your input, Aaron
EZB Connection by Synthiam
Create touchscreen robot control panels with buttons, joysticks, sliders, camera views and scripts; multi-page fullscreen UIs for PC and mobile.
EZB Connections by Synthiam
Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices.
Com Port Manager by Synthiam
Displays local PC COM/Serial ports opened by scripts, showing open/closed status (no communication logs); not the EZ-B UART.
Hi guys,
I finally received my mosfet switches for my connection failsafe.
I am having a hard time finding the setting for using D24 to monitor the connection.
Can anyone help me locate this in the ezb configuration?
Thanks, Aaron
#10   — Edited
The setting enabling the D23 connection monitoring is in the ezb web server.... Make sure you update your ezb4 x/2 to the latest firmware first...
Richard is absolutely correct, with up-to-date firmware on the EZ-Bv4.1/2, that option is in the Webserver settings under "Advanced Settings" in the "Network services" section. It's called port D23 connection status.
Hi guys,
Quick update, the problem was firmware.  I got the board updated and everything worked accordingly.  Great feature to have:)
Thank you, Aaron
