am going to try that as soon the batt is charged. then i make a new video,then they can see and start there projeckt. thanks ptp
PTP
i had some juice left in the batt. here is the rotation servo on gripper.
seromo hope you like it
here the jd calibrated,you will need to adjust the walk forwart&backwarts, and some more.when the jd makes a move ,you hear very low some noise, just lift the jd up for that and sound is gone. i will make some more video's later. happy building
