I made a long Jd I call him LD for long D here is the picture hope you guys like it And i was even able to move him and best part no extension cables were used.
seromo
— Edited
Auto Position (Gait)
— Create servo frames and actions to animate gaits and gestures with automatic motion planning, software ramping, movement panel, import/export
looking great,video plzz.
okay but long jd is not made right now I can post it in about 2 days or so when I re make it don't get mad please this is the time limit sorry
take your time.are you planning to gif him turneble elbows?
okay I will
Can you tell me how to do this? Aside from ordering the servos. How do you program him to walk with the extra joint?
you have to add a servo in the ARC software and write the port that it should control you can call the ez robot office sorry cant explain much because it is hard to explain
i made a little video with a long arm .has elbow and can turn grippers. if you maka your poses slow ( 45 ) it will be possible.
@Nomad
did you tried a different setup, e.g. connecting the rotation server directly to the gripper ?
