Jeremie could you tell me what the component was directly under the yellow poly fuse?
For some reason can't post a pic?
Pandorabots
— Connects ARC to Pandorabots for AI chat, sends text and gets replies (executes [EZ-Script]), integrates with speech recognition and custom bots
look at this lesson
fuse
It's not the fuse . It's a surface mounted component
Nomad that is part of the power base, I'm referring to the ezb itself , when you split the boards. Thanks though'
whits robot do you mean?
in the link you see all base. see under side page
Nomad this has nothing to do with the power base
How can I post a pic from my I phone ? I'm trying to use the attach file button but no luck. It says uploading ? And then nothing
you use what win7 or? i do it thru BT
