PWM Servo Ramping icon PWM Servo Ramping — Smoothly ramps PWM servos on EZB D0-D23 via Vx-to-Dx mapping for natural, gradual motion without snapping. Try it →
Singapore
Jd Claw Foam Inserts
Just received my new JD and going through battery charging and calibration prior to assembly. Attached to the inner of JD's claws are some foam inserts, and they seem to be attached very firmly, perhaps even glued in? None of the assembly instructions depict the foam and leaving them there would seem to offer a degree of resistance against the grippers closing completely.
Just wanted to triple check before removing the inserts that this is the correct procedure? If the inserts weren't attached so securely I would have had no hesitation but I don't want to ruin the poor guy if they are not supposed to be removed.
Sorry if this is a repeat question, I searched the forum for 'claw' , foam' and 'insert' with the Revolution JD tag but couldn't find anything relevant although I vaguely remember seeing a similar question posted previously.
Thanks for the advice.
Regards,
#17
Nice Job Richard! You beat me to it actually, I was going to try to work on a 3 finger modification of the claw this weekend. :):D
#18
@JustinRatliff LOL... Can't let you take all the design glory around here now can I... :) Anyway you're better at it than me so feel free to design your own... When I have more time I really want to start using OnShape to produce more complicated designs...
