Debug icon Debug — Central ARC debug window routing logs; shows UTC date/time, Windows/ARC/skill/hardware info, version/settings, with copy and clear. Try it →
United Arab Emr
Ip Cam Connection And Integration To ARC
Hi, I am new to EZB but I read much about it and I think we can benefit a lot out the HW and SW tools available.
I would like to have access to wifi ip cams single and multiple if possible , integrate it to the EZB software and use cam functionalities with ezb. I already ordered the wifi module to be able to connect using wifi at home. Your help is appreciated.
BR HH
#33
Ah ok , good to know , I figured any ip cams would work as long as they didn't use compression that had to be decoded like the parrot drone cam feed.
