Hi, I am new to EZB but I read much about it and I think we can benefit a lot out the HW and SW tools available.
I would like to have access to wifi ip cams single and multiple if possible , integrate it to the EZB software and use cam functionalities with ezb. I already ordered the wifi module to be able to connect using wifi at home. Your help is appreciated.
BR HH
I always ask as I've seen many do it but you did change the IP:port to the IP address of the camera and correct port... i.e. https://192.168.1.100:80
yes I did and I used the proper pwd it works to stream with VLC Sure something i am doing wrong or there is an issue with ASF . @Pittom : can you send me your setup for the foscam . I am using foscam 8910W
You need to use a jpg stream. Check the userguide for info on it, or wait for @pitcom to come on since he uses the same cam.
probably yes. I will wait for @pittom and try to check in the meantime thx
Try https://IP:port/snapshot.cgi or videostream.cgi
They may need the ?user= etc after them.
I did and not working If I use the browser . Snapshot is for jpeg. Videostream.cgi .... It does download a stream but does not show it as a video. Meaning it keeps downloading a file with no size limit.
video.cgi?
Same as videostream.cgi?
