Speech Synthesis icon Speech Synthesis — Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable. Try it →
Ideas To Attach A Tablet To Ezr Pan/tilt Servos
Ideas To Attach A Tablet To Ezr Pan/Tilt Servos
I would like to add Pan/Tilt to a Tablet to be the Robot Interface
besides the rotation & lever servo i will need: Clip'n'Play Adapter Plate Extension Cube
similar too:
The tablet is 7" and the weight is 370g (0.82 lbs)
some questions/issues:
  1. Tilt servo (Lever Servo) can a EZR HD servo handle 400g ?
  2. I will need a frame similar to (thingiverse):
but with a female EZ-BIT
I'm not familiar with 3d tools, zero "nada" skills!,
  1. anyone did something like that ?
  2. can someone build or adapt an existing frame to support a 7" tablet (119.77 x 196.33 x 15.36 mm) ?
  3. other ideas ?
any help/ideas will be appreciated:)
can you take the backside off? and take small wooden beam and screw it on. put some foam inside over the screws.see pic.
If your tablet has a car mount available, you could screw or glue an EZ mounting plate to the back.
Padholdr are pricey but have holders for almost every brand https://padholdr.com/collections/holders cheaper options available for popular models of tablet.
Not sure if the servos can manage the weight, but you can augment the stress points with springs or elastic.
i found a tablet kit car for $12:
front:
back:
maybe can be added to:
but it's not good, the servo needs to hold the position in 90 degrees
versus
the adapter below the frame (initial picture).
but so far i didn't found a holder with side brackets, and below and no upper brackets (tablet cameras)
Will this work? If you can print it and verify the size?
PanandTiltTablet.STL
Also, i can make a male clipn'play adapter plate.
@DJ,
yes you are on right track, the tablet dimensions are:
horizontal: 196.5 mm vertical: 85 mm (i reduced the size, to allow the usb connector to charge) thickness: 15.5 mm
those measures are the inside of the frame
regarding the clipn'play needs to be a female right ? to connect to lever servo.
btw i don't see the female clipn'play, only a plane frame.
wow, thanks!
Next step order the print. I let you know the final result.
Should i print in white to match the EZ bits ? or go with black.
