EZ-B V3 Configuration icon EZ-B V3 Configuration — Manage EZ-B hardware settings: edit Bluetooth name and apply updates to restore altered configurations. Try it →
Twitter
Ibm Watson Services Plugin
The IBM Watson Services plugin created by @PTP currently allows you to perform Speech to Text and Text to Speech as well as visual recognition using Watson Services.
You can download and install the plugin here https://www.ez-robot.com/EZ-Builder/Plugins/view/251
Before you can use the plugin, you will need to apply for a free 30 day trial of IBM Speech to Text Account here https://www.ibm.com/watson/services/speech-to-text and a free 30 day trial of IBM Text to Speech https://www.ibm.com/watson/services/text-to-speech/
I will create some examples as it moves forward and try to answer any how to questions.
Thanks for creating this PTP, as with all your plugins this is an excellent piece of work and showcase of your talents.
Twitter
#41
thanks @PTP sorry this was my bad. The problem was the person who included quotation marks in a programmed response. This was neither your issue or ez-Robots. What were they thinking ...
I like the new previous response test variable as I get lost in where we are in the conversation. Are we in the middle of a conversation or starting a new one?
#42
Wanna know the best option? Bluetooth earpiece:) they’re cheap and work really well. eBay or amazon for a few dollars and voila.
Just like the ones that cheesy real estate people where for their phone. Connects to your pc
Twitter
#43
I was actually going to use a Bluetooth hand held microphone. Had a lot of trouble with NAOs in the past in a crowded room doing demos. The robots built in mic’s pick up all the background noise so in a demo they don’t hear the commands. Hand held mic you can hand from person to person and the robot can only hear the person speaking.
PTP did some amaizing work on allowing you to configure DB levels and delays with the voice capture plugin he wrote so this makes it really easy to tune to the appropriate responses.
Twitter
#45
@ptp I am not sure what I am doing wrong, the variables in V7 only pass the first time and then I am not getting any updates to variables when I use the plugin . Maybe it is me? not sure. If I manually set variables they work fine.
@Nink,
Which service / script is not assigning the variables ?
Twitter
#47
It was all of the services. I was using assistant at time "move forward, move backward, robot dance etc" and it suddenly stopped working. I closed ez-robot did not fix it but variables would assign first time but not second. Ez-robot also kept hanging So I had to restart it several times (kill process as could not exit app). If I assigned a variable by a script worked fine but not via plugin. I must admit I did not test with other plugins (only Watson running).
Eventually I restarted my windows VM and problem went away. 8GB assigned to Windows only ez-robot running in VM (MAC Parralels) I will monitor today. Maybe I will try running native Win 10 and ez-robot on a Bare metal PC.
Twitter
#48
Seems to be behaving for me today so hopefully was just my PC. One other question, Occasionally I send no data to Watson using Speech to text (background noise etc) but it causes the Speech to text to stop.
