Target Overlay icon Target Overlay — Overlay translucent PNG targets onto a camera stream with loadable templates, attach/detach control, preview and status for visual alignment. Try it →
Twitter
Ibm Watson Services Plugin
The IBM Watson Services plugin created by @PTP currently allows you to perform Speech to Text and Text to Speech as well as visual recognition using Watson Services.
You can download and install the plugin here https://www.ez-robot.com/EZ-Builder/Plugins/view/251
Before you can use the plugin, you will need to apply for a free 30 day trial of IBM Speech to Text Account here https://www.ibm.com/watson/services/speech-to-text and a free 30 day trial of IBM Text to Speech https://www.ibm.com/watson/services/text-to-speech/
I will create some examples as it moves forward and try to answer any how to questions.
Thanks for creating this PTP, as with all your plugins this is an excellent piece of work and showcase of your talents.
@aryus96,
I tested with a .net core console project.
I'll check with a .NET project.
@aryus96:
I found the issue and is working with a windows.forms .net 4.6.1. I'll redo it again from zero to confirm the fix and I'll update the Watson's open ticket.
@aryus96: I've updated your ticket.
#68
@ptp Wow, Thank you very much ! I will check that out !
#69
Hi @ptp,
I'm starting to understand what's going on.
The TextToSpeech 2.11.0 isn't working with other versions of System.Net.Http than the 4.0.0.
When I run your code, I have to edit the AppConfig and remove the comment from the dependentAssembly of System.net.http otherwise it's loading the 4.1.0.
If I do that, I can run your code without any problem and it's working great.
But as I want to integrate it to ARC, I'm changing the project to a Class Library one, and not Window one. I add the debugger option, compiler, plugin.xml, path, etc.
I can load the plugin on ARC, however, it's loading the System.Net.http 4.1.0 even if the AppConfig is correctly setup. That means, ARC is using System.Net.Http and overwritting the use of the plugin one (4.0.0) ?
