Conversational Menu icon Conversational Menu — Voice menu tree to navigate options and run scripts on ARC robots. Multi-level, customizable prompts, speech I/O, timeout and repeat/back. Try it →
Resolved Resolved by Jeremie!
HELP NEEDED FOR 21DOF EZB HUMANOID ROBOT
I have been struggling to assign servo positions to my robot.
Old videos are either removed or are too old and doesn't seem to match the current software, so instructional videos look different and I'm simply having trouble trying to do something assigning servos.
Could someone please add a current link to current software that could help me?
As I've mentioned before it's been almost 5 years since doing this..last night i spent 3hrs trying to assign servos but i just couldn't do it, which was frustrating because i did it so easily years ago. It's intuitive up to a certain point, then i just don't know what I'm doing.
As mentioned previously all servos have been calibrated and the lower leg servos have been assigned through a multi-edit.
I don't know and can't remember how to drag the servo profiles to the image of the robot, unless i do that i simply can't proceed.
Create servo frames/actions to animate humanoid, hexapod or custom gaits with smooth transitions, SW ramping and directional control
Custom Movement Panel maps directional commands to scripts, adjusts per-wheel speed (0-255), and integrates with joysticks for unsupported motors
#25
Wow..i think you just made my learning easier thank you! And i was getting ready to get some zzZZZ's and it's almost 3am...I'll make a 4am curfew now.:D
I've got 5 servos for each leg so getting him to walk has been tricky, i stood up and walked whilst looking at myself understanding how his legs should be moving, i almost had him complete 2 steps but no where good enough so what you mentioned is going to help thanks again.:)
#26   — Edited
Where did you find the example projects i can't see them?
Found them.:)
#27
I think when you first turn on ARC the prompts ask if you want to see program examples. There should also be a link when you open the file saving to Synthiam cloud, I don't have it open here or I would know for sure, there is also JD walking sample programs you can check out on the Synthiam example cloud.
HI newagetomy
here you find the excamples .
Hi Nomad i found them many thanks.:)
Hey Nomad, when i turned robot on this morning i noticed ALL the frames i created last night have gone or rather i didn't save them correctly.
I have to re-assign all 22 servos again.:(
#30
Oh you likely forgot to save your project before closing down, sometimes I forget too and need to start over,LoL!
#31
It's strange because ARC asks if you want to save before exiting so i chose SAVE and yeah no frames.
But after doing it once i re-did them all in record time.:D
It's pouring rain outside so perfect day to progress,..hopefully progress.
Instead of a sit i had him doing the splits, can drop 4" off it's height when he drops.:)
hi bolt
i save them on my pc and in the cloud .
