the gyro works great,only jd does the motion twice?
— Edited
4 Participants
Brushless Motor Movement Panel
— Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement.
@nomad.
Show us the script you're using.
hi steve.
its says run once
Share your project by uploading the ezb file here.
i forgot how to do that.
@nomad.... look in you ez robot folder on your harddrive . Find your ezb project file... attach it to a post and upload it...
i try
jd-origineel.EZB
hope this works
@nomad.
yeah, the link for your project works fine. I had a quick look through it and can't see what is causing the issue I'm afraid. Hopefully someone else will be able to figure it out for you.
