Sharp IR Radar icon Sharp IR Radar — Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel Try it →
Ezbv Not Connecting
Ezbv Not Connecting
my appolegies to ask this again.i need an answer how to figur out, if the ezbv is damaged.i bouth a new one,and set it on Engenius. withs is just recently all set up by a pc repairman. the ezbv4 will not connect to the wifi,no matter what i try. it works in AP mode ,but i dont like this way.
my pc is set to englich language. other robot connect to wifi,but not for long.am out off ideas. any pointers anyone ?thanks.
#33
When you get the replacement let us know if you still can't connect and one of us will help you figure it out. If David is too busy working on EZ-AI, I'll be able to free up some time within a week or two to Skype with you, and I'll make notes on your network so we won't have to go through this again.
hi alan
i have allreddy the new one.i made notes too.in the mean im gonna call, my pc guy to look at it.not that i dont want to skype with you.but averybody is doing there stuff.withs is also importent.just set my nao for sale,it also dont connect due, aldebaran move on with the versions v5.0.double bummer .maybe i can make a video .
kamaroman68
you can contact me,click my icon pic you see my adres. remember that you can use the nao only in choreograph, no downloads,you have to make all motion yourself. there is no support for nao v3.3
#37
OK. When the PC guy gets it working, have him give you step by step notes, with SSID and Password you need to add to the EZ-B. I suspect that your Engenious may be having a problem since things that were working have stopped, and this is the second time in just a few weeks.
i had to renew my hardrive.from the destop.sinds then nothing. i think maybe i bin hacked.
its connected to wifi.i found a manuel same as my engenius. there where a few errors that i corrected with the manuel step by step. 1 default pasword is admin changed that averybody knows that. 2 capital letter in EnGenius the g was not capital 3 in the tutorial dj says not to change AP settings,its set to channel 1, and i put it on 11 like on engenius 4 is still a problem,in the manuel says something about speed set to 100% i can go to much less 29.i think thats why ezbv4 disconnects 5 two places where set to private and had to be set to public. i was very pleased to hear i have sucsesfull connected to your network
EnGenius manuel
